Go Back  Offshoreonly.com > Owners Forum > Doug Wright
32 Doug Wright Weight >
Old 02-04-2018 | 10:42 AM
1980Condor460's Avatar
Default 32 Doug Wright Weight
Anyone know what a 32 tips the scale at with 300's?
1980Condor460 is offline
Old 02-04-2018 | 01:27 PM
Ryan Beckley's Avatar
Racer
Racer
4500#ish
Ryan Beckley is offline
Old 02-04-2018 | 04:46 PM
I bet lighter
Double Rigged is offline
Old 02-04-2018 | 08:53 PM
The most recent (bare hull) weighed just over 2100. It was not a carbon boat so there is a couple hundred that could potentially be dropped.
Joe
JPEROG is offline
Old 02-04-2018 | 09:29 PM
Default Thanks
Thanks guys. I was thinking less than 5k. I have not put mine on the scales.
Old 02-04-2018 | 10:21 PM
Originally Posted by Ryan Beckley
4500#ish
What is the Stock Class minimum weight limit Ryan? The X-Cat minimum weight limit is 5,200#s on the hook at the end of the race, Stock Class is a lot less than that, isn't it?
Skater30 is offline
Old 02-05-2018 | 09:14 AM
Racer
Racer
Currently a newer 63" tunnel DW weight is 4300....minimum. Of course and older narrow tunnel boat, which I assume is what the OP here is asking about weighs much more, hence me saying 4500
Old 02-05-2018 | 08:36 PM
Wow, that is super light! I had no idea the Stock Class boats were allowed to be that light. Is that 4,300#s at the cranes at the end of the race, with any residual fuel, but no drivers in it?
Skater30 is offline
Old 02-06-2018 | 09:08 AM
ktron's Avatar
Yes, 4300# on the crane with no one in the boat as well as no helmets, no life jackets, no ballast.
ktron is offline
Old 02-07-2018 | 11:11 PM
I'm really surprised they've set the minimum weight that low. The inboard classes have much more realistic (safe) minimum weights. A 4,300# minimum weight for the Stock Class is encouraging the boat manufacturers to build them really light, which in turn is not as safe imo. What did your 32RT weigh complete/dry Daren? I thought I read somewhere at some point that it was 5,200#s? I'm doing everything I can to get my 30 to come in around 5,000-5,200#s complete/dry, but it's going to be tough because I'm starting with a boat that was built as an inboard boat that didn't have weight as the #1 concern.
Skater30 is offline
