Exhaust tips - Which kind are these? >
Old 02-09-2018 | 08:04 AM
Default Exhaust tips - Which kind are these?
Anyone know what brand/part these are? Do they have internal mufflers? Looking for angle tips, no mufflers
mine are currently straight
Attached Thumbnails Exhaust tips - Which kind are these?-13583795764.jpg   Exhaust tips - Which kind are these?-work-rack.jpg
frickstyle is offline
Old 02-09-2018 | 08:23 AM
Those are lipship tips, $3365/pair
ICDEDPPL is offline
Old 02-09-2018 | 08:57 AM
send me 4 then!
Old 02-09-2018 | 09:24 AM
Originally Posted by frickstyle
send me 4 then!
Is that yours on the right? Interested to know more about that setup. Looks super clean! Looks like thru-transom tails but without the goofy gasket like I have.
VortechSS is offline
Old 02-09-2018 | 09:41 AM
Yes it is. They are solid tails that bolt to the exhaust manifolds and run right out the transom. The exhaust hole cut in the transom gets sandwiched first with stainless ring inside > transom > rubber gasket outside > stainless ring outside. Then you just push the tail pipe thru from the inside. Very simple, and clean.
Old 02-09-2018 | 10:08 AM
Thumbs up
Better get a bigger can of NeverDull. Looks great.
sonicss42 is offline
Old 02-09-2018 | 12:17 PM
Great to know! Mine is the same but there is a gap between the ring ID and Tail OD on the transom that shows the rubber. Yours looks much nicer with no gap. I need some new rings!
Old 02-09-2018 | 03:25 PM
^Yep, just real tight fits.
Old 02-09-2018 | 11:32 PM
Here are ours...we opted for beauty rings on the inside too. Keeps it clean.
1MOSES1 is offline
1MOSES1 is offline
