454 CLOSED LOOP COOLING Question >
Old 02-11-2018 | 01:33 PM
Default 454 CLOSED LOOP COOLING Question
Hello, thanks for viewing. I'm putting together a Scarab 22 with a Gen 6 closed loop cooling system 454HO. Question is; while installing the aluminum intake manifold, my Fel-Pro marine gasket kit came with stainless restrictor plates for the intake gaskets. "DO I NEED THESE or just discard them. Thanks all!!
OSOUSMC is offline
Old 02-11-2018 | 09:50 PM
I don't use them in Mark IV or Gen V BBC's
f_inscreenname is offline
Old 02-12-2018 | 06:14 AM
Mbam's Avatar
Offshoreonly Advertiser
I think you are talking about restrictors for the heat riser passage in the center. Yes use them or even better block off completely.
Mbam is offline
