3 gauge pillar pod
Old 02-17-2018 | 03:26 PM
scippy's Avatar
Default 3 gauge pillar pod
Just ordered a pillar pod for my 2nd gen diesel truck...........What would be the top 3 gauges to install?...I'm leaning towards Fuel pressure 1st, Trans temp 2nd and EGT 3rd.
scippy is offline
Old 02-17-2018 | 03:32 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Do you have a boost gauge in the dash? If not, it would be a toss up for Boost or Fuel Pressure.
Sydwayz is offline
Old 02-17-2018 | 03:43 PM
scippy's Avatar
No boost gauge, but I know if fuel pressure gets way low it can eat up the vp44 lift pump in my Cummins diesel.
scippy is offline
Old 02-17-2018 | 03:54 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Yep, you are correct.
But it's also nice to know that when you are putting the pedal to it, towing up a long grade, that you are not putting too much boost to your top end.
4 gauge pod available?
Sydwayz is offline
Old 02-17-2018 | 04:26 PM
Boost, EGT and Trans
If your pump starts loosing pressure I would bet you would notice the loss in power
AllDodge is offline
Old 02-17-2018 | 04:53 PM
No need for a boost gauge in that truck unless your diagnosing an issue.
Fuel pressure
trans temp
egt.
those 3 will let you know what your about to kill
Unlimited jd is offline
Old 02-17-2018 | 04:59 PM
scippy's Avatar
The gauges are 2-1/16"........only room for 3 on the A- pillar........maybe a forth atop steering column lol
scippy is offline
Old 02-17-2018 | 05:02 PM
scippy's Avatar
Fuel pressure
trans temp
egt.
That's my thoughts as well............Fuel , Trans & EGT
scippy is offline
Old 02-17-2018 | 05:07 PM
scippy's Avatar
I was told (but don't know for sure) the loss of pressure that often KO's the lift pump can be traced back to an undersized or faulty fuel pump.
scippy is offline
Old 02-17-2018 | 05:22 PM
What fuel pressure are you told to look for?
class6 is offline
