Which damper plate to use for 500hp and Bravo >
Old 03-05-2018 | 06:46 PM
Default Which damper plate to use for 500hp and Bravo
I have a stock (recently new) oem merc damper plate. Its the triangle shape one (3 bolts I think). Do I need to be concerned with it being able to handle a power upgrade? I will be adding at least 100hp/tq to the 330hp it was intended for and wonder if its strong enough.
This build is killing my wallet and hoping I might be ok. Also im running a Bravo 3 so maybe its a good weak link in the chain to save the drive?
Any advise here is appreciated. Oh and if I need to upgrade the damper will I need a different bell housing too? Right now what I have is the 330hp bravo stuff.
pjv911 is offline
Old 03-05-2018 | 08:26 PM
i would update to a hp500 coupler,your bell housing is good,same as a 500.
mike tkach is offline
Old 03-05-2018 | 10:24 PM
I'll look it up and see if I can get one.
Have you used my type and had a failure?
or know of someone that has.
Surely a more expensive stronger damper is better. I just want to know it's needed.
pjv911 is offline
Old 03-05-2018 | 11:00 PM
pjv911 is offline
