Project Boat Part out. 31 Corsa
I recently purchased a long time project boat.
Hull is a mid 90's build Corsa hull. When I got the hull there was not even a drain plug hole drilled. Hull has never been in the water, but it has had some bad luck. Was in a fire and had some melted roofing dropped on it. Structurally it's like new. But cosmetically it needs some attention.
I have boxes of parts some used some new. I'll add them as I dig through them. Here are some key parts ready to be sold now.
31 Corsa Hul cut for number 3 drive.
1998 Aluminium Tri Axel Trailer never in water under 200 miles on it. $3800.00
Latham Stainless Hydraulic Rams with transom mounts $800
Lantham Tilt Helm with pump, brand new. Pending Sale.
Latham Stainless Trim Tab Rams $400
Black Trim Tab Rams, look new. $300
Wolverine Marine Racing Trim Tabs, these are some time capsule tabs.. great condition need some paint. $600
(2) Two Trim Pumps, these look brand new but do have oil in them. $175 each.
I will make a package deal on the tabs. Just let me know which rams you want and we can work something out.
Number 3 Gimbal looks like new, has a little paint peeling on top.
Number 3 Drive 1.5 ratio, condition I would say 7 out of 10.
(3) Speedmaster Trim Cylinders great condition.
Bell Housing with dual coolers, coolers included.
Will make package or separate.
Old School Kiekhaefer offshore cast aluminum oil pan. $350
Old School Weiand BBC Timing cover with access hole to degree cam without removing it. $50
(2) Weiand 177 Blowers $600 each
(1) Holley Intake Manifold for Weiand 177 blower, looks brand new $200.00
Offshore motor mount with rear mount plate. This has a bend at the mount but can easily be straightened. $Best offer.
MerCruiser / Gil manifolds and stainless risers, these are longer to fit number 3 boat. Fresh powdercoat and have been pressure tested. $1200.00
2 drive 2 tab indicator panel with cables. Missing some parts.
I'm not sure on some of the prices yet, I have to do some research to see what things are going for. If you see an item I listed you want that does not have a price feel free to make me an offer.
More pictures coming later tonight.
Pics of tabs to [email protected]
I was told they were gone through. I have only opened the boxes to look at them so far. Have not tried to spin them and see how they feel. I’ll check them out tonight and get get back to you with pictures. They look used but look pretty good.
These are in boxes from dollar offshore. The guy I bought the stuff from said they went through them and they have not been bolted to anything since. They both spin and souls like they should when rotating. That’s really all I know about them.
