Project Boat Part out. 31 Corsa
I recently purchased a long time project boat.
Hull is a mid 90's build Corsa hull. When I got the hull there was not even a drain plug hole drilled. Hull has never been in the water, but it has had some bad luck. Was in a fire and had some melted roofing dropped on it. Structurally it's like new. But cosmetically it needs some attention.
I have boxes of parts some used some new. I'll add them as I dig through them. Here are some key parts ready to be sold now.
31 Corsa Hul cut for number 3 drive.
1998 Aluminium Tri Axel Trailer never in water under 200 miles on it. $3800.00
Latham Stainless Hydraulic Rams with transom mounts $800
Lantham Tilt Helm with pump, brand new. Pending Sale.
Latham Stainless Trim Tab Rams $400
Black Trim Tab Rams, look new. $300
Wolverine Marine Racing Trim Tabs, these are some time capsule tabs.. great condition need some paint. $600
(2) Two Trim Pumps, these look brand new but do have oil in them. $175 each.
I will make a package deal on the tabs. Just let me know which rams you want and we can work something out.
Number 3 Gimbal looks like new, has a little paint peeling on top.
Number 3 Drive 1.5 ratio, condition I would say 7 out of 10.
(3) Speedmaster Trim Cylinders great condition.
Bell Housing with dual coolers, coolers included.
Will make package or separate.
Old School Kiekhaefer offshore cast aluminum oil pan. $350
Old School Weiand BBC Timing cover with access hole to degree cam without removing it. $50
(2) Weiand 177 Blowers $600 each
(1) Holley Intake Manifold for Weiand 177 blower, looks brand new $200.00
Offshore motor mount with rear mount plate. This has a bend at the mount but can easily be straightened. $Best offer.
MerCruiser / Gil manifolds and stainless risers, these are longer to fit number 3 boat. Fresh powdercoat and have been pressure tested. $1200.00
2 drive 2 tab indicator panel with cables. Missing some parts.
I'm not sure on some of the prices yet, I have to do some research to see what things are going for. If you see an item I listed you want that does not have a price feel free to make me an offer.
More pictures coming later tonight.
