Hardin Marine oil filter mount leak fest >
Old 04-19-2018 | 08:04 PM
Default Hardin Marine oil filter mount leak fest
Running the vertical mount with the big filter and have used both Moroso and K&N and both leak horribly. This is a new build and this is only from priming the engine. Oil leaking out of where the filter meets the mount. No imperfections on the mount side perfectly smooth and very tight. Looks nice but hate leaks. Anyone else have this issue?
Tahoe540 is offline
Old 04-19-2018 | 09:19 PM
I posted about the same issue here before. I even emailed Hardin about it but no response. I put some uv dye in the oil and shined a black light on it and it was actually an invisible leak coming from the fitting and threads above it pooling on the lip of the filter. I tried new fittings, different sealers, under torquing, over torquing with not much luck. I ran into other issues before getting to the bottom of it but I hate the friggin mess.
Baja Rooster is offline
Old 04-20-2018 | 06:58 AM
Had one cost me 20K for rebuild and a DNF in Cocoa Beach 2017.
Steve
smiklos@sunprint is offline
Old 04-20-2018 | 12:12 PM
Steve
How exactly did it fail?
Old 04-20-2018 | 02:12 PM
Remote Oil Filter Kit
I have had good luck with this one.
Chris
Blueabyss is offline
Old 04-20-2018 | 02:56 PM
Try this, clean the filter head matting surface real good. Take a new filter and barely apply a thin film of oil on the gasket. Screw filter on until the gasket just touches the filter head. Remove it and see if there is an imprint of the gasket on the surface all around
AllDodge is offline
Old 04-20-2018 | 04:42 PM
Wobble's Avatar
SORE MEMBER
It looks like the gasket is overlapping the flange, not good
Wobble is offline
Old 04-20-2018 | 05:34 PM
I have used both the bigger and smaller filter you can run with this setup and even the smaller filter leaks out of the same area around the gasket. I have taken it off and on more times than I care to count to try and see why. Seal looks perfect with both size filters but I agree the bigger filter does overlap the flange. Sucks as these are not cheap. Hate to even say it but was considering a light smear of RTV on the gasket.
Tahoe540 is offline
Old 04-20-2018 | 08:32 PM
Same here. I kept trying different filters at ~$30 a pop.
Old 04-20-2018 | 08:43 PM
I have the Teague one...hopefully its dfferent and doesnt have the same problems... TCM BIL067
phragle is offline
