Reliable BBCs - back to basics >
Old 04-27-2018 | 11:28 AM
Default Reliable BBCs - back to basics
Smart folks on this site with engines pushing the limits of BBC combustion engines so I thought I would ask a question only experienced boaters can answer:
What are your key factors that make your Big Block marine engines reliable? What Achilles heels have you fixed or tweaked to mitigate future reliability issues?
I am looking to refresh my power in 2018 - something in the reliable 500HP range and thinking maybe I should think about tweaking things like fuel delivery, cooling, electrical, to make things more reliable or eaier to maintain. Ideas?
Swamplizard is offline
Old 04-28-2018 | 09:24 AM
Guess the smart guys are off boating ... or ... they dont want to share their wisdom 😏
Old 04-28-2018 | 09:49 AM
bck's Avatar
bck
Charter Member#568
Might have better luck in the technical section.
Straight bottoms and flat decks
bck is offline
Old 04-28-2018 | 10:22 AM
Nothing wrong with a 502 mag mpi, hp500, 500efi, 525sc, bulldog, 575sci, 600sci or 700sci. All reliable motors, copying any of those isn’t a bad idea if you aren’t an engine guru.
You can make more power with better heads than any of those had. Your head setup is critical, so hire a pro for that. You can also gain some valvetrain reliability with 55-60mm cam cores, bigger lifters and rocker stud girdles or shaft rockers. Tool steel valve springs, steel body rockers, bushed lifters and rollers, billet core cams....
But at 500hp a lot of that stuff isn’t needed, 500 is childs play.
Stainless marine and thunder n lightning are probably the call for reliable exhaust.
hogie roll is offline
Old 04-28-2018 | 10:58 AM
I’d recommend calling a reputable marine engine builder and tell them what you currently have and what you want. Someone like Eddie Young will kit and sell you the parts you need. If you want to do the work yourself I’m sure he’ll walk through the steps over the phone.
SecondWind is offline
Old 04-28-2018 | 11:07 AM
I’ve always like a 502mag mpi motor, with a cam, and a tune and exhaust. Refresh the top end with HD valve springs and roller rockers, and bam you have a pretty much stock reliable 502 with 500hp
also the hp500 carb motor is pretty cheap and reliable
marks86 is offline
Old 04-28-2018 | 11:38 AM
With possible exception of the headers, Mercury seems to have gotten it right with the 525 EFI.
thirdchildhood is offline
Old 04-30-2018 | 05:14 AM
Dave M's Avatar
Veteran: Navy
All the BBc's I owned were reliable. The drives on the other hand.............
Dave M is offline
