Fuel pressure loss at high rpm >
Old 05-03-2018 | 02:17 PM
Default Fuel pressure loss at high rpm
Looking for some help tracking down a fuel pressure issue. Port & star both idle at 7lbs. At around 3800, port begins to fall off and sometimes dumps right off to 1 above 4500. I get out of it at that point so I’m unsure if I’d lose it completely above 5. Occasionally if I walk it up really slowly, pressure will hold. Things I’ve already tried
-swapped upper&lower pump(both new 2x)
-new fuel lines from tank to carb
-inspected tank, no issues or anti siphon
-swapped senders& gauges from other engine(same result)
-ran fuel line directly into 5gal can to eliminate a tank problem
-lobe seems fine in water pump. Changed oil
-bypassed water separator
i did run it in a hose once while looking in the tank. The only odd thing a noticed was that when throttled back to idle quickly, an air bubble spit out of the pick up tube. I have no idea what would cause air introduction since I’ve replaced every line.
Sonichunter is offline
Old 05-03-2018 | 02:46 PM
tank vent lines kinked?
SS496 is offline
Old 05-03-2018 | 02:57 PM
I lightly pressurized the tank. Movement through the vent. Also ran from a gas can on a quick run to eliminate a tank issue.
Old 05-03-2018 | 07:15 PM
Check your fuel pressure regulator
blaquebaja is offline
Old 05-03-2018 | 08:21 PM
The lower is a KE self regulator between 6-8psi. No
other regulators.
Old 05-04-2018 | 01:03 AM
How much HP and what size fuel lines??
Griff is offline
Old 05-04-2018 | 03:31 AM
560 with -8 lines. The pump should be able to support 800+ hp.
Old 05-04-2018 | 10:24 PM
Nobody’s dealt with a similar issue ?
Old 05-05-2018 | 05:56 AM
Suction hose collapsing ?
Unlimited jd is offline
Old 05-05-2018 | 07:13 AM
Rookie's Avatar
Pump part #?
Rookie is offline
