Cam bearing material? >
Old 05-03-2018 | 06:03 PM
Default Cam bearing material?
Getting my machining done and need to install new call bearings what's better material to go with, babbit or Silicon aluminum (Si)?
My spring pressures are 160/400, 1.7 rockers, 629/612 lift.
Mohavvalley is offline
Old 05-03-2018 | 08:04 PM
14 apache's Avatar
I would go babbit think its better for dirt
14 apache is offline
Old 05-04-2018 | 01:31 PM
So the general consensus is babbit and not aluminum silicon?
Old 05-04-2018 | 02:47 PM
14 apache's Avatar
Dart blocks come with babbit. Just use durabond bearings they are probably the best.
Old 05-05-2018 | 11:40 PM
Ok durabondbond babbits it is, thanks Apache
Old 05-06-2018 | 08:15 PM
I will second the Durabonds. That is all I use.
BillK is offline
Old 05-06-2018 | 08:56 PM
Rookie's Avatar
I just bought/used 2 sets of Durabond myself.
Rookie is offline
Old 05-10-2018 | 02:46 AM
Are you also using durabonds on the rods and mains over clevite or king or are you just using them on can bearings?
Old 05-10-2018 | 07:05 AM
Durabond only makes camshaft bearings, not mains and rods. I have had very good luck with Clevite bearings over the years and dont like to change just for the sake of changing I have tried some King bearings lately but they seem to vary a lot as far as thickness goes Interesting since one of their selling points is their "bullseye" tolerance.
BillK is offline
Old 05-10-2018 | 09:54 AM
convincor's Avatar
Durabond does offer a "coated" option if your going have it sitting for a while with spring pressures on the cam.
Had a cam bearing spin once because of this.
convincor is offline
