260 pulls right
Just bought a 2002 260 with 240 hrs on her she has a 496 with bravo 1 outdrive just wondering if anyone has an issue with the boat turning hard right when you trim the out drive up at speed or when you are coming off plane
What I was finding was running about 35-40 I would start to bring the drive up and all on a sudden the boat would make a hard right turn this also happened when I was coming off plane the boat made a hard right turn. Is there such thing as to much trim at that speed ?
With external hydraulic steering you should NOT be able to move the drive side to side at all.
With cable type steering there will be some play side to side but not more than an inch.
You have a serious problem - DON"T drive the boat until you get it fixed.
