502 build advise
Hello everyone
new to the forums
i searched the forums for answers before I posted so not to put up yet another build thread
to start I have a 2000 33 outlaw twin 502 mag mpi’s that are stock
my thoughts are to pull the low hour mills and freshen up with a hone and rings and bearings on the bottom end. Then have heads checked and install inconels on the exhaust and springs to match the yet to be determined cam.
i am wanting a fairly mild 600ish hp and was leaning towards a 8/71 with twin 750’s along with manifolds like imco powerflows with risers. Forgot to add that the oil cooler will be upgraded. Boat has full hydraulic to the helm.
please share some of your experiences with a somewhat budget build along with do’s and don’t
Thanks in advance
new to the forums
Thanks in advance
My recommendation would be to leave well enough alone. If you can’t do that then buy some already made power out of the swap shop here as there’s a multitude of reputable sellers here and sell the stock power for a pretty penny. If you can’t do that then call Eddie Young who is incredibly helpful to the community will save you literally boat loads of grief and money.
600hp is commonly attained with some good heads and Crane 168741 cam, and your Bravo drives may actually live through the summer.
You should actually call Eddie first and he can answer what you’re looking for.
I think stock CR is 8.75. You could run maybe 7psi non intercooled on an 8-71 with that. Exhaust you should check out the thunder n lightning cast aluminum. Dry to tip tails will let you get aggressive with the cam. Most people like the 741 cam, it is the 525 efi cam I believe, or similar. That combo would make 700-800hp depending on cam and boost.
