575SCi mechanical fuel pump - Rebuild? >
Old 05-14-2018 | 09:37 AM
Default 575SCi mechanical fuel pump - Rebuild?
The last day of last season I had a terrible rich running issue with my boat. This weekend I finally got it up and running again, and it took roughly 4 seconds to figure out the problem once I got it started. The back third of the (mechanical) fuel pump was shooting fuel out of it!! Real Bad!!
I took the fuel pump apart and it seems like I could get another gasket/diaphragm/rubber piece thingy to put in there. But, I'm not sure if there was an internal failure to the pump that caused it to rupture (i.e. high pressure fuel dead heading infernally where it's not supposed to be?
Are these pumps rebuildable? If they are, should I bother?
Thanks!
PowerAddict is offline
Old 05-14-2018 | 09:43 AM
how soon do you need one?
my 575 is out for repairs and i could part with the pump, has 15Xh on it
LTZCrew is offline
Old 05-14-2018 | 10:33 AM
dcb
Airtex 60932, about 69.00 if I recall.
dcb is offline
Old 05-14-2018 | 03:14 PM
Wow. You guys are awesome!
LTZ: I don't need one for a few weeks. We wont' be having it out until the week of 4th of July. I could buy that one off of you, but, won't you need it again? or are you going full electric?
Old 05-14-2018 | 09:32 PM
full electric. turfin the TBI
LTZCrew is offline
Old 05-15-2018 | 08:44 AM
That pump has 1/4 NPT inlet and outlet. Its more suited to an NA 454 than a Blown 502. I bought one and sent it back for that reason.
Old Navy is offline
Old 05-15-2018 | 09:57 AM
Thank you for that info.
Old 05-15-2018 | 02:37 PM
dcb
Used that exact pump on my 575 SCIs - just swapped fittings from my old pump - this is just a lift pump to supply the cool fuel. 575 SCI and 525 efi use the same lift pump. Just replaced one on my current 525s with this p/n.
dcb is offline
Old 05-15-2018 | 03:18 PM
dcb
[ UOTE=SB;4532260]Airtex 60932 fuel pumps for the sea water mount are just $55.88 thru Amazon: Link: http://a.co/9FlecL7
Many people believe this is whom makes it for Mercruiser.
Airtex Fuel Pumps » » Single Product
http://www.offshoreonly.com/forums/d...fuel-pump.html
You could then also get the pumps mentioned above to swap the lowers.
Just a thought.
Edit in: most parts places sell Airtex stuff also...therefore Amazon isn't the only place...I just used it for reference.
Also, I have not done this....just relaying info I've studied. When I did the bottom swap years ago, the Aitex pump was not available outside of Mercruiser.[/QUOTE]
Here is a quote from another thread on this subject
dcb is offline
Old 05-15-2018 | 05:50 PM
Just a thought.
Here is a quote from another thread on this subject[/QUOTE]
Thanks so much for doing all that, I'll certainly reference it!
