Stiff Steering >
Stiff Steering
Stiff Steering
Old 05-14-2018 | 07:29 PM
Default Stiff Steering
Hi all I have a 2007 26 Outlaw. Question- the steering is stiff and I am hearing this is the way it is. Is this true? If not, what can I do to make it less stiff? thanks
Kent is offline
Old 05-15-2018 | 01:27 AM
What kind of steering??
Cable??? Add On Hyd?? or Full Hyd??
Griff is offline
Old 05-15-2018 | 02:04 PM
Default cable
hey there
it is cable, any ideas??
Kent is offline
Old 05-16-2018 | 01:34 AM
It could be the helm, in the rack or cables in between. Its hard to say without being able to feel how stiff. It might be nothing.
It shouldn't be any stiffer than any other single engine engine cable steering. Try to find another boat with cable steering and compare.
You would definitely like full hyd and full hyd keeps gimble rings from going bad since the load is on the rams and not the steering pin.
Griff is offline
Old 05-16-2018 | 06:52 AM
Default Thanks Griff
Ok I will look into this, my friend has the same boat.
Kent is offline
