Fast fuel injection
Care to elaborate apache?? I'm also curious about FAST...what was a nightmare?? tuning, performance, customer support?? Would running their dist. tied in with the fuel injection have helped your situation??
The box is sensitive to rf noise and a msd box is not good for that has a lot of RF. I had to have a lot of capacitors to help the problem out even used resistor plugs to help with the problems. Even the pickup for the crank trigger was close to the alternator was a problem. If it had Hall triggers it may of not happened. I am not the only one with these issues. Maybe the newer ones are different but I would stick with a holley and do individual coils or a batch fired coil. Took two weeks to figure out what was going on with it would sit there and just shut off like it hit the revlimiter.
