changing prop direction
Old 05-21-2018 | 01:17 PM
Default changing prop direction
I was told it was not hard to change prop direction. I have a twin engine Eliminator Daytona. I am not very mechanical i know i have to switch props. Can some one walk me through how to change the shifters to be opposite of what they are now? Thanks
ROMO2233 is offline
Old 05-21-2018 | 01:41 PM
Bravo's I assume? If so, just pull your shifters out. One will have the cable coming in from the front and one will have the cable coming from the rear. The cables will need to be reversed. If it is on the front, move it to the rear. The one on the rear, needs to be moved to the front. If you just want to try it before you do all of the work, you can just switch props and run it in reverse for forward and forward for reverse.
snapmorgan is offline
Old 05-21-2018 | 02:21 PM
I will try that first. Just worried about docking...lol So i need t
o pull shifters out? I thought i did it on the motor side. Now i need to figure how the shifters come off
ROMO2233 is offline
