Prop Hub Play
Over the weekend I changed props and noticed one hub had some play within the prop and the other was rock solid. Do these things wear out? Flo-Torque II Solid Hub Kit 1.25” shaft.
We carry snubber kits which can snug up the inserts.
Here is a link.
https://bblades.com/shop/accessories...-strip-kit-hd/
Brett
Here is a link.
Brett
[email protected]
[email protected]
Yes. The hub and propeller are cast. There are tolerances and if they are each at max of the opposite ends we can have additional play. This is of no concern since we still have a square plug in a square hole.
Make sure the prop nt is tigh and there should be no prop rattle.
Brett
[email protected]
[email protected]
