Boarding Ladder Recommendations
Looking for an under the platform telescoping ladder. I've looked at several online so I'm looking for real world experience. I have Arnesons so accidentally leaving the ladder down will be disastrous, (maybe self retracting or spring loaded). Going on a 388 Hustler. Whatcha got?
this ladder / very similar ladder was on my last boat, "but it was mounted on top of the platform down in a pocket
with a hatch over it" it worked very well, telescoped in and out and into the channel no problems.
in your case i would make a strap or 2 that holds it in place. put straps on the wheel/ throttles/ shifters/ ignition etc,
while the ladder was deployed so they are in your way before you start the engines.
I am using this one , it's a little pricey but works well although I have the push button style
Stainless steel drop down telescoping ladders for our aluminum swim platforms, fiberglass swim platforms or teak swim platforms. Perfect for your baja, baja outlaw, active thunder, advantage, american offshore, apache, awesome, baja, black thunder, c
