Bleeding brake lines
Old 06-14-2018 | 01:00 PM
Default Bleeding brake lines
I have a tri axel Vanguard trailer with electric over hydraulic brakes and while pulling to Michigan yesterday i lost my brakes about 50 miles from my destination. The inside of the hub and caliper are covered in brake fluid and i could see a trail of fluid on the pavement behind my trailer (had to hit brakes due to sudden slow down of traffic). Brake lines are good and show no breaks/leaks so I assumed I lost a seal/gasket on the caliper piston. So i have ordered a new Kodiak 225 brake caliper and it looks easy enough to install after watching the videos. I have bled the brakes on my old surge brake system but how do you bleed them on the elec./hydraulic? the new caliper will be on the last wheel on the passenger side of the trailer, do i have to work my way through each wheel bleeding out the air or can i just open the valve and pump the brakes until i get fluid out of the new caliper?
bigredbaja is online now
Old 06-14-2018 | 01:11 PM
Have someone press the brake pedal or actuate the manual lever to power up the EOH unit. Start at the farthest caliper and work your way forward. It most likely drained the reservoir so you'll need to bleed all calipers.
payuppsucker is offline
Old 06-14-2018 | 02:08 PM
We just converted friend's trailer to EOH and used a vacuum bleeder (basically a small Mity-Vac). Worked like a charm. Took about 20 min.
Gimme Fuel is offline
Old 06-15-2018 | 01:57 PM
https://www.harborfreight.com/brake-...der-92924.html
only way to bleed brakes... truck, car, trailer
30outlaw is offline
Old 06-15-2018 | 02:20 PM
If you will be at Buzzard the first of the week I will be there and more than happy to help you, just let me know.
Gary
GLENAMY 242SS is offline
Old 06-15-2018 | 02:32 PM
Wouldn’t an engine oil extractor pump work as a mitt vac since we all have one laying around anyways?
Baja Rooster is offline
Old 06-16-2018 | 05:48 PM
Hand vacuum bleeder at the farthest caliper and working to the closest to the master cylinder. Followed by actuating the emergency lever manually like you're pumping your truck's brake pedal again from farthest caliper to nearest.
I hope you got the SS Kodiak's the rest are a waste of time and money as they're only going to fail again. I also RTV the outer boot's channel on the caliper and piston as per another member's recommendation here to prevent water intrusion.
Tractionless is offline
