Trim TAB Question >
Trim TAB Question
Trim TAB Question
Old 06-15-2018 | 05:09 PM
Default Trim TAB Question
A generic question... when the tabs are full up should they be even or tilted up from the hull running surface. And how far should the tilt up be?
thanks
PA.WOODCHUCK is offline
Old 06-15-2018 | 07:14 PM
rak rua's Avatar
They should be tilted up from the running surface.
How much, depends on the tab and the transom angle but I'd say a good 10-15 degrees. If you have tab gauges, most people adjust the gauges to read '0' when the tabs are aligned with the bottom of the hull (horizontal).
RR
rak rua is offline
Old 06-16-2018 | 12:12 PM
madbouyz's Avatar
When you buy tabs to install yourself the instructions will generally say that you have to run a straight edge off of the hull bottom to the end of the tab . At that point the end of the tab should fall X amount of inches above the straight edge when fully retracted . I believe it's something like a minimum of 1.75 - 2"
madbouyz is offline
