Old school BBC not starting >
Old 06-19-2018 | 10:18 PM
Default Old school BBC not starting
I have a 1994 Scarab 31 with twin 454/365 carb mags. Boat ran great last year. This year starboard engine fired right up ran fine. Port engine wont start.
It cranks over easily
Put a few squirts of gas down the carb, same
I swapped the module from the other engine, same
I checked every fuse I could find, all good.
My wife cranked the engine and I had no 12v across the pos/neg terminals on the coil.
Anyone? Thanks
pullmytrigger is offline
Old 06-20-2018 | 06:02 AM
convincor's Avatar
Is there a low oil pressure cut-off switch?
convincor is offline
Old 06-20-2018 | 06:35 AM
SB
Start in middle column.
At first, Use another ground (then the - coil term) when you are checking for 12 volts at the coil +.
SB is offline
Old 06-20-2018 | 06:39 AM
I'd put a jumper wire on the 12v terminal of the coil and connect to a 12v source,then try and start.work backwards from there if it fires.
sutphen 30 is offline
Old 06-21-2018 | 12:13 AM
With the key on I had 12v from the pos term on the coil to a bare spot on the block
Old 06-21-2018 | 12:53 AM
BUP
ignition sensor under the distributor cap then under the rotor,
Buy OEM - they are a bit higher cost like 24 dollars more.
I have 20 in stock if whomever needs any. The OEM is made here in Florida at Merc plant 7. the rest after market ones are made in China.
Story -- those china ones can have issues after the engine heat soaks. How do I know just replaced 2 last week but the boat owners saved 24 dollars buying them online --- China made one. . The potting material is not that good in alot of the China made ones, this is one of the issues from the start. FYI
And for best results there is a special install to do for the current ones.
BUP is offline
Old 06-21-2018 | 10:58 AM
bck's Avatar
bck
Charter Member#568
What's your contact info for getting some BUP ? I'd like to have a couple spares for the T bolt IV.
Straight bottoms and flat decks
bck is offline
Old 06-21-2018 | 11:22 AM
BUP
OSO PM sent to you. THANKS
BUP is offline
