time to step up to the plate >
Old 06-21-2018 | 06:48 PM
ROB FREEMAN's Avatar
Default time to step up to the plate
well after many years of reading. ive decided to giveit a shot , pulling a motor to change coupler . probly just move engine forward , question is , can I use strap off intake on fully dressed motor , thought about going under whole intake and lifting , but not sure about that either . what you guys think.. thanks again rob
ROB FREEMAN is offline
Old 06-21-2018 | 07:02 PM
Does the engine have lifting eyes? If so, that’s what I use. You can run a bolt into the front of the head. There’s several ways to do it
endeavor1 is offline
Old 06-21-2018 | 07:22 PM
nope no lifting rings , bummed out , that's a lot of weight on carb intake bolts im thinking .
Old 06-21-2018 | 07:28 PM
File Type: mov
Old 06-21-2018 | 07:38 PM
Just buy lifting plates and screw them on the two adjecent corners. Use grade 8 bolts if you are nervous. They are only like $30
Keith Atlanta is offline
Old 06-21-2018 | 07:46 PM
Lifting plate bolted to the carb bolts with a harbor freight 1/2ton chain hoist worked like a champ for me. If you have an airgap intake just run a strap through it.
Baja Rooster is offline
Old 06-21-2018 | 09:31 PM
I also found electric towers to be a useful gantry, lol.
Old 06-21-2018 | 09:56 PM
Wtf
getrdunn is offline
Old 06-21-2018 | 11:31 PM
BUP
Originally Posted by getrdunn
Wtf
^^^^ That alone is cracking me up --- for some reason that is killing me. LMAO
Must work for the local electric power company is all I can think off. Glad its grounded. If not that Baja would be going Baba
the tower even has a warning sign on it . Prob says WARNING HIGH VOLTAGE STAY 3000 FT AWAY.
BUP is offline
Old 06-21-2018 | 11:35 PM
BUP
Have a bunch of these and drilled out for all different hole patterns Just one example in the pic -- Works for many apps
BUP is offline
