Cam chain clearance to block >
Old 06-28-2018 | 10:06 AM
Default Cam chain clearance to block
I just put on a Rollmaster CS2090 and it looks super close to the #1 side of the block. I saw a note in the box that some grinding may be needed so I guess this is what they were talking about? No marks or scraping sounds when turning over to degree the cam.
Baja Rooster is offline
Old 06-28-2018 | 11:08 AM
Can you push it towards the block and cause the chain to make contact at any point?
payuppsucker is offline
Old 06-28-2018 | 11:17 AM
Hard to tell. I’ll try to stick a feeler gauge behind it as I can’t tell if it’s hitting the block or sprocket. Is this a common issue?
Old 06-28-2018 | 11:24 AM
F-2 Speedy's Avatar
Is this a step nose cam with the retainer, cant recall from your other thread on which one to buy
F-2 Speedy is offline
Old 06-28-2018 | 11:25 AM
I can't answer that question but it definitely looks close.
Old 06-28-2018 | 11:26 AM
I was just about to say "maybe speedy will chime in here".
Old 06-28-2018 | 11:29 AM
Yep. Gen VI step nose with retainer. Chain set has the Torrington bearing.
Old 06-28-2018 | 11:35 AM
F-2 Speedy's Avatar
I guess if they send a note in the box their product has clearance issues in some cases. that really blow's who wants to grind on a new build
Old 06-28-2018 | 11:43 AM
A little annoyed about grinding on a fresh engine and will have to tape everything off like heart surgery. I guess the trade off is that it *may* fit under the factory cover (it’s a lot easier to grind/replace the cover though). Otherwise it’s a really nice set for the money. Installed the cam straight up and was within a half degree of spec.
Old 06-28-2018 | 11:55 AM
F-2 Speedy's Avatar
Did you price Cloyes, just curios how they priced out............never used roll master
