HP500 backflush
Does anyone have instructions on how to backflush a HP500? I think you disconnect the oil cooler hose and run water through there but not sure which hose on the bottom to disconnect to let the water flow out. I tried searching for a water flow diagram but couldn't find one.
Thanks!
Thanks!
Thanks for the info. If hooking a hose up to flush, do you connect it to end of the oil cooler and flush opposite normal water flow?
