2003 496 HO Checking fuel pressure >
Old 07-16-2018 | 12:46 PM
Default 2003 496 HO Checking fuel pressure
guys,
can you point me in the direction of the parts I need to check the fuel pressure in my 2003 sonic prowler? Is there a kit I can buy or do I just come up with the parts? The reason I ask for this detail is that the boat is 3 hours from me and in a rural area. I only go on weekends so my options for parts are limited to Saturday morning till about noon. I would like to gather all of what I need at home where I have accsss to parts and take with me.
Pictures of the setup would be great as well.
kevin
chevy57 is offline
Old 07-16-2018 | 04:40 PM
Does the 2003 496 have a Schrader valve and can I use it?
chevy57 is offline
Old 07-17-2018 | 09:11 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Yes, there is a Schrader valve on top of the engine, starboard side of the engine. You will need to remove the plastic top cover, and you will see it. It's under/behind a hose if I remember correctly.
Something like this should work for you:
https://smile.amazon.com/dp/B000EVU8...aa_pcomp_aapi1
Sydwayz is offline
Old 07-17-2018 | 09:24 AM
Thanks I ordered that kit yesterday.
kevin
chevy57 is offline
