Ambient air power loss
Old 07-30-2018 | 04:45 PM
Default Ambient air power loss
When is 110 degrees on the lake, how much power loss or MPH loss do you get? N/A engines. How much can I expect? Water temp around 88 degrees
Cerberus66 is offline
Old 07-30-2018 | 05:13 PM
Supply elevation above sea level, barometric pressure, and humidity and I can give you the figure.
GETTINBYE is offline
Old 07-30-2018 | 06:34 PM
SB
Expect 1%hp loss per 10*F rise in inlet air temps...assuming engine is tuned correctly for the weather change.
SB is online now
