Go Back  Offshoreonly.com > Owners Forum > Nordic
Fuel tank switch will not switch over to other tank >
Old 08-01-2018 | 01:24 PM
Default Fuel tank switch will not switch over to other tank
I have a 2007 Nordic Rage and the fuel tank switch will not switch over. Any ideas what the problem is ?
wetdrmz is offline
Old 08-01-2018 | 01:32 PM
BBYSTWY's Avatar
if its the imco valve...I have the same one in my heat and the electric actuator took a dump last year and I had to replace it...there are a couple fuses on that valve as well...you can buy the ram separate from imco
BBYSTWY is offline
Old 08-01-2018 | 02:52 PM
Is this boat new to you? Can you hear the actuator moving, but not switching? Someone may have pulled the pin out and didn't get it back through the hole in the actuator.
snapmorgan is offline
Old 08-02-2018 | 08:40 AM
Thanks for the info
wetdrmz is offline
