Looking for a good 2001 6.2 bare block
casting number is 10243880
needs to be original to swap original pistons and the rest to replace a cracked block...
anyone have that? Cant even order a new one from merc
thanks
thanks
Most stroker cranks require a little clearancing on the block, but your machinist will.should know this.
Speaking of which, this block is super common....your engine guy may even have one. If not, sure as schit he can/will get one for you.
just as said above...that number is coming up as a 5.7
Search Results for '10243880' - Casting Numbers .info: engine blocks, heads, and more
they are a dime a dozen from all the trucks that used them from 95-99
-Wally
-Wally
