Oil & PS coolers >
Oil & PS coolers
Oil & PS coolers
Old 08-10-2018 | 05:23 PM
Default Oil & PS coolers
So my 502 is now becoming a 509 so with the added HP can I run a separate oil cooler and PS cooler? What size will be need for both and should I use this also.
Big Block Chevy Gen 5 & 6 Thermostatically Controlled Engine Block Adapter
Any suggest are welcome as I'm just now starting to understand this boat world......
Texascuda is offline
Old 08-10-2018 | 07:11 PM
I run the 1000hp version of this one with good results...
MRC CPH-750
Boatally Insane is offline
Old 08-13-2018 | 03:44 PM
A few questions, so the cooler I have now is 3" x 20" is this to small for the 509? Second question I'm going to sell the complete MPI system, Upper & lower intake with throttle body all sensors, wiring harness, MEFI1, fuel rails with injectors, MSD distributor, VST tank, remote oil filer mount with lines, what should this be worth?
Regards
Old 08-14-2018 | 08:35 AM
3 X 20" Is plenty for what you are doing what intake setup are you going to run??
kip4234 is offline
Old 08-14-2018 | 08:40 AM
Thanks kip4234, was going to use Victor Jr with AFR 305 heads, Holley Sniper going to send my risers to Eddie Young for 02 bungs.
Old 08-14-2018 | 10:14 AM
I have a 3x18” cooler on my 509 and had to put a thermostat on it as it was cooling a bit too much. My setup is very close to yours so keep us posted on how the Sniper works for you as a lot of us are curious about it.
Baja Rooster is offline
Old 08-14-2018 | 10:28 AM
Will do, I'm also going with the thermostat block adapter, Young Performance is going to add the 02 bung and extend the inner pipe for me to keep the 02 dry. Alex at Haxby Speed is going to help me with the tune.
Old 08-14-2018 | 12:00 PM
Btw, there is some good power left on the table with those Victor Jr manifolds if you don’t mind taking a hour to grind them out. The ports are made small so that builders have plenty of material to match the ports on whatever heads they choose. I only bothered to match the gasket but it still really opened things up.
Old 08-14-2018 | 05:49 PM
So while the motor is out, hope this shows
Old 08-15-2018 | 10:32 AM
Why did you unbolt the motor mounts from engine instead of taking off the one bolt?😎
1BIGJIM is offline
