8.2 mag ho Stalling when hot >
Old 08-13-2018 | 12:00 PM
Default 8.2 mag ho Stalling when hot
Hello have a 2012 Monterey 328 SS with twin 8.2 HO mag's. One has been starting to stall like it is running out of fuel when hot. I have seen a few people mention vapor lock ? I changed fuel filter still does it. Let cool for an hour or so and will start back up ? No alarms no beeps just dies out ? Any ideas would be great.
Matt
Michigan Matt is offline
Old 08-13-2018 | 12:11 PM
VoodooRob's Avatar
What codes are you getting?
VoodooRob is offline
Old 08-13-2018 | 12:29 PM
BUP
this is catalyst engine for sure not nothing close to old school 502 / 8.2 L.
Many things can make these engines stall. I sugguest a OEM Merc cerc shop to look at it. Many systems on this app anyone working on it can make matters worse inwhich can become costly. I would start with fuel samples and fuel pressure testing. Improper cooling components can cause the engine to stall as well. There is pop off valves and check balls for cooling systems in these apps -- they must be checked and maintained all the time. Also the gen 3 cool fuel system is problem child and most likely has internal paint peeling causing fuel restrictions and really messing up the injectors.
WORD of warning many shops and injector services are clueless about the fuel injectors that the new 8.2 use. Different testing and cleaning procedures are needed for these injectors. They are calibrated totally different than persay the standard fuel injectors. Again this is solid info here that one would NOT hear anywhere else about these injectors.
BUP is offline
Old 08-13-2018 | 03:07 PM
Not to side track the OP's question, but the paint in the modules happened a long time ago and was covered under bulletin for the first series of the Gen 3 pumps. All the stock was cleared out and has not happened since from what I've seen and heard. Your saying that with the cat motors Merc has the paint issue showing up again?
AllDodge is offline
Old 08-13-2018 | 04:04 PM
Nothing to do with paint, since your engine starts fine when cool and if you can run it for extended periods on plane you are having vapor lock, you need to check the flow of water through the cool fuel module it can get restricted due to salt, corrosion or other..
cooper_361 is offline
Old 08-13-2018 | 08:30 PM
BUP
2012 had paint internal in the GEN 3 cool fuel Merc. I do the cat engine injectors all the time and they have paint all over the place. the paint issue stopped around 2013 or 2014 depending on when Merc phased out the painted internal cool fuels.
Eddie Young can valid exactly what I am saying about this, cause just recently we had a long conversion over these cool fuels and year models. You can reach out and ask him as well.
BUP is offline
Old 08-13-2018 | 08:35 PM
BUP
depending on how much paint - the engine will still run and some still run fairly well but the restrictions cause the fuel pumps to overheat inwhich cause vapor lock. Also this app for cooling has check balls and poppet valves can cause more heat on top of, In return cause vapor lock, Fuel pressure testing is in order.
YES WILL AGREE also for any cooling water flow restrictions in and out of the cool fuel as well.
BUP is offline
Old 08-13-2018 | 08:38 PM
BUP
can you provide me the SB that EXACTLY shows the end of the internal paint for the GEN 3 cool fuel ?
BUP is offline
Old 08-13-2018 | 08:45 PM
BUP
this Merc SB has nothing to do with paint but for the cooling hose change and no bracket. Just in case if you were going to post this exact SB.
ZERO any info about paint internally but all about cooling hoses
http://www.mercruiserparts.com/bulle...2009/EN_01.PDF
BUP is offline
Old 08-14-2018 | 07:04 AM
Your asking me for the bulletin, that gets me scratching my head real good. Having a hard time believing your asking me. It was done in conjunction with Bul 09-01, Merc never admitted paint was the issue
https://www.perfprotech.com/blog/tec...rvice-bulletin
AllDodge is offline
