Gen 5 & 6 Thermostatically Controlled Engine Block Adapter >
Old 08-17-2018 | 02:25 PM
Default Gen 5 & 6 Thermostatically Controlled Engine Block Adapter
In regards to the Gen 5 & 6 Thermostatically Controlled Engine Block Adapter, do I still want to use the 30lbs bypass in the block. I have heard no and also yes anyone using this now did you keep the bypass? I will be using -12an line from adapter to remote oil filter and to the cooler.
Regards,
Steve
Texascuda is offline
Old 08-17-2018 | 03:09 PM
Regardless of oil cooler or not I’ve only seen encouragement to remove the center one and block off the outer with a small freeze plug.
Baja Rooster is offline
Old 08-17-2018 | 03:15 PM
Yep that's one of the opinions I was told also.............
