How many GPM is a Gen 7 sea pump? >
Old 08-27-2018 | 06:55 AM
Default How many GPM is a Gen 7 sea pump?
Im looking to see how many gallons per minute a gen 7 sea pump is to make sure its sufficient for the closed cooling system i installed this week.
axm0z5h is offline
Old 08-27-2018 | 07:44 AM
Almost a gallon a second at speed.
underpsi68 is offline
Old 08-27-2018 | 07:56 AM
That should work for my application then. The heat exchanger said it needs 35gpm. for some reason the engine is overheating. I rebuilt the sea pump, put in the ss wear plates and new impeller. Im just trying to narrow down what could be causing this
axm0z5h is offline
Old 08-27-2018 | 08:57 AM
Try the power steering cooler. Pull and clean it out.
Keith Atlanta is offline
Old 08-27-2018 | 12:36 PM
The p/s cooler on my 496 was a straight through design. The oil cooler would collect all the debris.
Old 08-27-2018 | 12:44 PM
i put the hose directly into the sea strainer and my issue went away. Looks like the issue is the hose in the transom assembly. im going to install a thru transom water pickup tonight.
axm0z5h is offline
