YOUR HELP NEEDED: Intermittent Shifting Issues with Volvo Penta D6-350 / DPH Drives >
Old 08-28-2018 | 10:51 AM
Advantage's Avatar
Default YOUR HELP NEEDED: Intermittent Shifting Issues with Volvo Penta D6-350 / DPH Drives
I am having some intermittent shifting issues with my D6-350 / DPH drives.
Thing runs and shifts great when itīs cold, but as soon as the boat gets to operating temperature the issues starts to occur. At times, the starboard drive will not engage forward (from neutral). The port side shifts all the time every time.
And the issue on the starboard side seems to be happening more and more frequently as time goes on (like 1 out of 5 times). If I bump the RPMīs up slightly from neutral it will engage forward most of the time but not every time.
Is this a sign that my shifter cables need adjusting or replaced entirely? Also, I am not getting any fault or error codes on my EVC.
Advantage is offline
Old 09-06-2018 | 01:27 PM
C_Spray's Avatar
Diamond Member #001
I know that on my DPX drives, that is usually a simple shift cable adjustment (assuming that yours are mechanically shifted). It can be adjusted either at the shifters or at the drive.
C_Spray is offline
Old 08-07-2019 | 05:25 AM
Hi, did you solve this. What was the root cause in the end ?
npm108 is offline
Old 08-22-2019 | 10:15 AM
You can shoot some lube like "chain and cable" into the electric shift actuators. Its just a worm drive that does dry out. I would not use wd40 as it dries out quickly.
fossil fuel is offline
Old 08-25-2019 | 09:39 AM
It wasn’t the shift cable... something in the drive, I forget but I’m sure Derek will chime in...
alindquist is offline
