Air fuel ratio sensor kit >
Old 09-05-2018 | 03:23 PM
Default Air fuel ratio sensor kit
I'm pretty sure I will be getting an AEM X series AFR kit, unless anyone on here has a good reason not to.
One issue I am having is whether they have longer cables. The supplied cable is only 8 feet long and I'd want a longer setup so I can view the gauge while I am running at speed. I'm going to do more searches on this but if anyone has information I'd appreciate it.
NHGuy is offline
Old 09-05-2018 | 03:28 PM
if it is 4.9 the connectors should all be the same sooo, the Innovations 25' extension cables should work correct?
GLENAMY 242SS is offline
fugedaboudit. Guy at AEM says they can be extended...
I should phone before I post.
NHGuy is offline
Old 09-06-2018 | 12:10 AM
I just use the Innovate extension cable to get it to the dash.
Trash is offline
