2000 32 wants to porpoise
I have a 2000 32 with all aluminu ls3 motors making 650 hp and 565 torque it wants to. Chine and porpoise at 80 mph
im running stock 28 bravo1 props I’m going to try some 15x29 mirage plus 3 blades
I know the factory ran Bravo I props on the big block Dominators and Mirage Plus on those with the small blocks (6.2L's). Just for chits and gigs, have you tried adding weight in the stern to see if it helps? I know Dominators do not like to be over-trimmed.
Pics?!
Pics?!
I remember the first time I ran yours WOT and tried to trim it like my Crownline and you could feel it starting to slide around on the pad getting ready to chine walk. Bump the trim down a bit and it goes away with no loss of speed. I think this was a different day than the one I tried to run it into the cliff in the State Park.
I was thinking the same thing. Try adding a little weight to the stern ( like 200 to 300 lbs ) and see if that helps.
Installing those all aluminum engines removed a lot of weight from the stern.
You moved the CG way forward.
Just my opinion, but I doubt it is engine weight, considering mine behaved the same way regardless of fuel load. But it consistently disliked being over trimmed no matter fuel or peeps load in the boat. Engines look awesome!
