top end refresh
Old 09-09-2018 | 03:58 PM
Default top end refresh
I have approx 400 hours on my 525 s, time for refresh ,how much should it cost and whats the best components to use?Also reccomendations on someone to do it in the upstate NY region , thanks in advance for any input
156600ld is offline
Old 09-09-2018 | 06:27 PM
What year motors? That will determine if the heads need to be pulled or not.
apex svt is offline
Old 09-10-2018 | 12:52 AM
At 400hrs, the heads need pulled. New head gaskets springs, locks, retainers and valve job.
A lot of good info here 525 EFI how many hours...
Griff is offline
Old 09-10-2018 | 06:24 AM
I agree with griff. At a minimum heads need to be pulled. Head gaskets are notorious for leaking. On top of that valves should be inspected (reversion) and valve job. Springs need to be replaced and for the cost of lifters and rockers, I’d just replace them now. It’s cheap insurance and piece of mind.
Cost really depends on who you use and how much of the work you plan to do yourself.
If you plan to pull engines and dis-assemble and re-assemble you can save quite a bit of money. Engine pull and re-install is $1000-1200 alone.
Parts for both engines will be around 3-4k (assuming you opt for new lifters $600-800 per engine).
Labor for motor work is kind of a crap shoot. I’d figure $1200-2000 per motor if they are doing tear down and setup (I.e valve train, valve job, etc.).
1MOSES1 is offline
Old 09-10-2018 | 06:44 AM
VoodooRob's Avatar
I agree with the above post, do it all. Engines will run top notch and at full rpm you wont be wondering if rocker bearings are going to explode. Also pressure check the headers, flow test/rebuild injectors and change spark plug wires.
VoodooRob is offline
Old 09-10-2018 | 07:33 AM
SB
Saris' are in Lake George, NY. They are longtime OSO members and offshore racers too.
Performance Marine » About Us
https://www.facebook.com/TeamSaris
Originally Posted by TeamSaris
We'd be happy to talk to you as well. Tyler is a personal friend a great guy, Eddie does great work too. No reason to bash anyone. We're certainly less of a hike though...
Saris Racing Engines/Performance Marine
518-644-3080
500-1500hp with warranties. One of Whipple's original 3 dealers, in business since 1987, Mercury Racing Dealer and Premier Service Center.
Good luck with whatever you do!
SB is offline
Old 09-10-2018 | 07:50 AM
Knot 4 Me's Avatar
Definitely address the headers while doing the top ends.
Knot 4 Me is offline
Old 09-10-2018 | 12:43 PM
I just posted on my rebuild experience in the General Discussion section, did full rebuilds at 470 hrs
one Piston had a broken ring when we did the tear down so not sure if that would have been discovered if just doing the heads???
you can PM me for pricing I was quoted but that was 2015
papps is offline
