Distributor gear for Comp Cams billet stick? >
Old 09-13-2018 | 02:51 PM
Default Distributor gear for Comp Cams billet stick?
Brand new Comp Cams billet hydraulic roller cam 525EFI clone with DUI distributor. I’m trying to figure out what gear I currently have, or I guess the best option is the composite unit?
Baja Rooster is offline
Old 09-13-2018 | 02:53 PM
SB
What is the part# of the cam ?
SB is offline
Old 09-13-2018 | 03:05 PM
Part# 01-446-8w
It says that it’s a pressed on cast gear on the cam.
Old 09-13-2018 | 07:05 PM
Originally Posted by Baja Rooster
Part# 01-446-8w
If that is the case then a stock gear will work fine. I prefer to replace them when going with a new camshaft.
BillK is offline
Old 09-13-2018 | 07:16 PM
A hardened steel gear, correct?
Old 09-13-2018 | 07:47 PM
SB
Part# 01-446-8w
Thanks, that's why I asked. Stock cast iron gear will suffice. Cam has same gear a flat tappet cam could have.
SB is offline
Old 09-13-2018 | 09:04 PM
Thanks all. The one question I had was does this look like a cast gear or steel?
