Thermostat housings for Weiand 177 454s? >
Old 09-18-2018 | 08:35 AM
Default Thermostat housings for Weiand 177 454s?
Guys,
Apologies for all the questions but planning out blower install. What thermo housings are you using?
Specifics:
454 Mags
Gil Exhausts - raw water dumps
Closed cooling with Merc heat exchangers cooling manifolds and block
Standard Merc recirc pumps for now.
Want to make sure whatever I use will not cause clearance issues.
Thanks!
Swamp
Swamplizard is offline
Old 09-18-2018 | 08:51 AM
BBYSTWY's Avatar
Not sure about the closed cooling but my 525 SC had a standard BBC like a 420 style thermostat housing...it had a hole drilled and tapped in the top with the plastic check ball deal in it for the upper water feeds on the elbows...like I said not sure if that will work for closed cooling or not...your current housings won't fit??
Stewart
BBYSTWY is offline
Old 09-18-2018 | 09:51 AM
to be honest they are the old school ones and have seen better days so planning to replace. I like the stainless ones I've seen around but weiand instructions seem to point to a thermo relocation kit??? Will see when I mock everything up but trying to get ahead of it.....so install can happen over a weekend without waiting for parts. Thanks for inputs!
Old 09-18-2018 | 09:57 AM
BBYSTWY's Avatar
Have you checked Hardin marine?? they had all different shapes and sizes when I was shopping for one...might be worth a look??
BBYSTWY is offline
Old 09-19-2018 | 08:01 PM
SkiDoc is offline
Old 09-19-2018 | 08:03 PM
I believe that this is what you need. Happen to have two!
SkiDoc is offline
Old 09-19-2018 | 11:04 PM
I have the Stainless Marine ones, I have crossovers and do not have closed cooling though. Her is a pic of my setup.
RBeyer is offline
Old 09-19-2018 | 11:37 PM
You will need offsets like SkiDoc posted unless you have the Merc 525SC intake manifolds. The Merc 525SC intakes have a built in offset already.
Griff is offline
Old 09-20-2018 | 06:38 AM
Thanks Gents- they are SCs but are in transit so didnt realize they were offset. 🤔😁
Old 09-20-2018 | 01:06 PM
525Sc pic
Griff is offline
