Gen 6 502 over size pistons >
Old 09-26-2018 | 06:57 AM
Default Gen 6 502 over size pistons
I have a chance of getting my hands on a Gen 6 502 which had a riser gasket fail with low compression in two cylinders for cheap, looking around for pistons I see they only make 4.500 as the next size. The only play I find a .030 over is GM Performance which is a little pricey
Could anyone advice me if this is the only way to go and can the Gen 6 be bored out to 4.500 with no problems?
Thanks in advance
Camalot is offline
Old 09-26-2018 | 07:06 AM
Sorry guy's I was looking at the wrong spec sheet lol I see stock bore is 4.465.............opps
Camalot is offline
Old 09-26-2018 | 07:34 AM
F-2 Speedy's Avatar
many things can cause low compression, it may not even need bored, have you pulled it apart ?
F-2 Speedy is offline
Old 09-26-2018 | 08:14 AM
GPM
GPM is offline
Old 09-26-2018 | 09:27 AM
Your right and the bores could well be okay, but it's almost free well a trade with a gen 4 block I have and would want to rebuild it anyway ........it has quite a few hours on it.
Camalot is offline
Old 09-26-2018 | 09:30 AM
Originally Posted by GPM
4.47
Thanks for the correction I've altered it now, fat finger don't type to well lol
Camalot is offline
Old 09-26-2018 | 10:05 AM
JE makes a set .002 oversized. If everything else is good you can get away with a good honing with torque plates and be better than new. I’d still lean towards boring it out though as the expenses for parts are the same.
http://www.jepistons.com/Catalogs/SR...placement.aspx
Baja Rooster is offline
