What Type of Solenoid for Sterndrives >
Old 09-28-2018 | 05:55 PM
Default What Type of Solenoid for Sterndrives
I have a 2004 Powerquest 380 Avenger with the 525 EFI engines... Would anybody know what Model Number solenoids I need for the Bravo 1 Sterndrive?
brianracedesert is offline
Old 09-28-2018 | 06:22 PM
Could figure it out with a motor serial number, and assuming trim relays?????
AllDodge is offline
Old 09-28-2018 | 07:23 PM
does have trim relays .. just acquired this boat .. where are the engine serial numbers located ?
Old 09-28-2018 | 07:27 PM
Look for a plate above the starter on the block
Now if the trim does not work, How is it not working?
AllDodge is offline
Old 09-28-2018 | 07:59 PM
I had a mobile boat repairman come out and found out the solenoids were bad.... Thanks for you help.. I will see if I can find serial number .. Its going down in the abyss in the engine compartment .. LOL
Old 10-02-2018 | 12:02 PM
Best bet is to pull a solenoid and match em up.
Tractionless is offline
Old 10-02-2018 | 12:29 PM
VoodooRob's Avatar
525EFI, 600SCI, 700SCI all have the serial #s in the same location on the heat exchanger just look at top of engine above the belt.
VoodooRob is offline
Old 10-02-2018 | 12:40 PM
Old 10-02-2018 | 12:44 PM
Use the model number of the trim pump, not the engine.
TexomaPowerboater is offline
Old 10-02-2018 | 01:59 PM
VoodooRob's Avatar
I agree pull the part and google match the #. Posted the picture so you can find your serial number of your engines.
