LSA Engine Open Cooling?
Changing out the 377 in my 2009 Pachanga... Ordered a Crate LSA 6.2 All aluminum engine from GM Performance. I only run fresh water lakes in Northern Ontario/Manitoba Canada. Looking for your thoughts on running an open cooling system & closed system for supercharger intercooler with remote oil cooler including a filter/screen via electric circulation pump like used on a camaro/corvette.
You may want to get information from someone smarter than me on why its "not for marine use"
JMO - If I were to go with that engine I would go with a closed system due to corrosion inhibition and probably easier to maintain operating temp
You need a closed system for many reason and for longevity. Electric water pumps basically are short duration and how does it adjust for the ever wide changing RPMs that a marine engine goes thru for hours on end ? Yes they are great for drag racing and so forth but thats blast off and shut the engine off in 10 seconds -- no hours of on and off the throttles for a jist to see water flow spikes / volumes and water temp drops & spikes. Plus has any one done YEARS of testing for duration with electric water pumps in the complete marine enviroment on open water cooling systems ??
A closed system will maintain constant temps alot better thru out all rpms and that helps and keeps the expansion rates were they need to be with aluminum engines and those parts for a jist. Then you have the corrosion issues but thats really a no brainer.
I think a member ( corey331) did an ls into a checkmate a while ago.... if I remember right he said the motor was pretty corroded within one summer of fresh water running, and went to closed cooling after that.
aluminum will corrode in fresh water as well...saltwater just speeds it up, run closed system, also ALL GM crate engines listed as "not for marine use" they sell componants to a 3rd party to build "marine" engines and all warranty is thru them.
GM Marine Engines | GM Powertrain Marine
