Metal in Heads..Where Could It Be From? >
Old 10-19-2018 | 08:21 PM
Rage's Avatar
Default Metal in Heads..Where Could It Be From?
I found tiny brite shinny metal bits in oil filter. They are iron based since magnet attracts them. Pulled the valve covers and found the same in the low spots of pooled oil. I inspected the roller rockers and the valve stem tips. These look in perfect condition.... I mean perfect. I expected to see some spalling of the valve stem tips or rocker rollers but not. I have not yet inspected the springs and retainers. What other source could deposit this metal in the head area?
Rage is offline
Old 10-19-2018 | 09:30 PM
Camshaft ??
Griff is offline
Old 10-19-2018 | 09:47 PM
could use more information on engine like what camshaft,what valve springs and what material the retainers are made from.also do they have aftermarket valve seals.
mike tkach is offline
Old 10-19-2018 | 10:36 PM
Rage's Avatar
It is a Mercruiser 496 that has little left that is stock other than block and accessories. Valve springs are PAC 1295x beehive and PAC steel retainers. Cam is custom mfg by Cammotion. Trend push rods, JE forged pistons, TotalSeal gapless rings, Crane aluminum exhaust and scorpion aluminum intake roller rockers, Melling high volume oil pump, Ferrea super alloy valves, stock Mercruiser lifters, Scat forged stroker crank, brass valve guides, Clevite bearings, forged Scat H rods, Comp Cam Viton valve stem seals.
Basically just want to know what/where ferrus metal can come from that can get onto top of heads.
Rage is offline
Old 10-19-2018 | 11:01 PM
Almost all of the internal parts of that engine, excluding bearings, pistons, valves and guides, and maybe the distributor gear are ferrous (magnetic).
i would look or use a magnet in the discharge passage of the oil filter and see if it’s there, then work my way through the oiling system until it starts showing up. If that doesn’t work... which it probably won’t, I would check the cam drive and distributor, then the lifters/cam.
oil pump is unlikely since it’s under the valve covers
is this a new build, how many hours running?
sailtexas186548 is offline
Old 10-19-2018 | 11:08 PM
i had one apart that had the springs in the valve seals brake,looks like small shiny junk in the pan and short little parts laying in the heads.these were hp500s with dart aluminum heads and a big hyd roller cam.they were just plain tired engines.
Old 10-19-2018 | 11:19 PM
Rage's Avatar
Thanks. The valve stem seals replaced about 40 hours ago.
90 hours on rebuilt engine. I understand what all is ferrus and what can wear. That is not my question. My question is only what ferrus components when they wear or fail their debris can physically show up on the top of the heads?
Rage is offline
Old 10-19-2018 | 11:47 PM
Follow the oil... lifters-pushrods-rockers-valves-retainers/springs/guides. Make sure your push rod guides are not wearing.
I would pull some rockers and pushrods, take a good look at everything, if you don’t find anything then pull the intake and look at the lifters.
i have seen so many failures where metal gets to places you would never believe so there’s that too...
Old 10-20-2018 | 07:26 AM
Valve spring shims, especially if they didn’t use hardened shims at the top of the stack
Unlimited jd is offline
Old 10-21-2018 | 12:36 PM
I'd pull it as much of a pain it might seem. Inspect everything to get to the root of the problem and you'll sleep better.
getrdunn is offline
