IMCO Nose Cone on XR Lowers - Is it worth putting on? >
Old 10-25-2018 | 01:30 PM
GNJ's Avatar
GNJ
Default IMCO Nose Cone on XR Lowers - Is it worth putting on?
I have a Hustler 388 with standard lower XR drives running in the low 90's. Wondering if IMCO nose cones would gain some speed and reduce prop slip.
Anybody?
GNJ is offline
Old 10-25-2018 | 02:22 PM
from what i understand they start to become needed around the 80 and up mark.
beaver 3 is offline
Old 10-25-2018 | 03:50 PM
GPM
Can't hurt, will feed the prop better, may handle slightly different.
GPM is online now
Old 10-25-2018 | 06:20 PM
Before you do that, tap the 5 holes in the nose of the drive, screw in plugs and make sure your boat can handle cooling from only the side water pickups. If you still run cool, I bet you get 2 MPH just having them plugged. Then, its up to you if you do the nose cones. You can get the allen plug kit at Harbor Freight for like $8
I've heard a lot of fountain stories that the drivers are high enough that they dont get water thru the side water pickups since they are so close to the surface.
Keith Atlanta is offline
Old 10-25-2018 | 06:56 PM
GNJ's Avatar
GNJ
Thanks Keith, However, My drives don't have the holes in the nose of the drive, rather there are 4 machined 1/4" slots under the nose that channel water to the inside under portion of the nose of the drive. No way to tap and screw plugs into that design plus whipple recommended plugging the sides of dual water pickup drives to increase water pressure and prevent steam pockets on whipple charged motors like mine.
GNJ is offline
Old 10-26-2018 | 03:35 AM
So you get more Water when close the side pickups??
i have an Dualwater lower with side and front pickups!
i look for more water in my SCi engine and maybe this is a way?
Can you post a pick from your new lowwater inlet??
Michael
Brembofreak is offline
Old 10-26-2018 | 09:49 AM
GNJ's Avatar
GNJ
Michael
CRITICAL!!!
Mike - Here is a cut from my Whipple install manual. Ill try to take a pic of the water pickup and post it later -
WHIPPLE LAKE TEST POST - INSTALLATION CHECKLIST
After installing the Whipple supercharger kit it is imperative that the following checklist be performed. Failure to perform these simple tests may result in severe engine damage.
1. Make sure 91 octane or higher is in the vessel. If unsure, then drain the tank completely empty and fill with 91 or higher. 2. With the thermostat removed, under full throttle operation, near full speed, block pressure should be a minimum of 25lbs. and maximum of 35lbs. If block pressure is not present, severe engine damage may occur. The motor should have 03lbs. at idle and should progressively get higher as speeds increase. A low water nose style pickup or external pickup may need to be installed. The Mercury side hole pickups will not generate enough water flow for proper operation. If you have an XZ drive with dual water pickups, it is be necessary to plug side draft holes to increase pressure.
GNJ is offline
Old 10-26-2018 | 09:55 AM
F-2 Speedy's Avatar
Are you running a crossover on the water jacket at the rear of the intake
F-2 Speedy is offline
Old 10-26-2018 | 10:03 AM
GNJ's Avatar
GNJ
Yes my kits came with 1/4" lines and fittings on each side of the intake to relieve steam pockets.
GNJ is offline
Old 10-26-2018 | 10:06 AM
F-2 Speedy's Avatar
Are you discharging that or are the two sides tied together
