Go Back  Offshoreonly.com > Owners Forum > Powerquest
Silent choice on 380 avenger >
Old 11-08-2018 | 09:00 AM
Default Silent choice on 380 avenger
I'm looking for info on removing the silent choice and factor thru hull baffle and replacing them with straight thru hull dry pipes. Anyone have any info or have done this?
Rippinantearin is offline
Old 11-16-2018 | 08:37 AM
You could just pull the diverters out and replace them with a straight black exhaust hose and then cap the Y-pipe oval openings.
Another option is just remove the Q&Q pipe and replace it with a thru hull exhaust modification pipe and new tips.
Now the right way would be to remove both engines, remove the Y-pipes all together and install the block off plate for the thru prop exhaust opening. Then remove the Q&Q tips wile the engines are out and install new tips of your liking.
92nsx is offline
