V Band Connections with Wet Exhaust?
I am assuming V band connections on wet exhaust will work fine? I have a relatively complex side exit exhaust set up (inboard mufflers, H-pipe, switchable exhaust); love the sound, but dismantling the system for any reason is like going through a back to back MMA match . I think a couple of strategically placed V band connections in the system will make things much easier to disassemble should the need arise. It looks as if various gaskets can also be used if a watertight seal is not achieved. Anyone have any knowledge or experience for this application? Any reason not to try?Thanks in advance!
