Pantera 28 performance ??? >
Old 11-18-2018 | 05:49 PM
Default Pantera 28 performance ???
What numbers are you seeing with your setup and how does it handle im thinking about a re rig
cheers gerry
gerrypantera is offline
Old 11-18-2018 | 09:14 PM
bigboat28's Avatar
99 with 502 mags and 28 Bravo's that did 76mph
88 with 643 hp 555s and speed Master IIIs with 17.5 x 29s that has done 82 mph so far
bigboat28 is offline
Old 11-19-2018 | 04:40 PM
How did it handle with those setups any porpoise issues ?
Old 11-19-2018 | 06:01 PM
bigboat28's Avatar
What do you have?
Old 11-19-2018 | 06:05 PM
bigboat28's Avatar
The 99 did fine, the 88 with the speed Master and transmissions is very Stern heavy. You have to drive it and use tabs. It has a bow tank that last time out I filled with water and it rode lot better.
Old 11-20-2018 | 11:58 AM
cheers gerry
yes re rig it you know you want to and Gift me your cummins motors . I hope this is you Gerard!!
paul buckner is offline
Old 11-20-2018 | 12:03 PM
How much water does your bow tank hold Big boat
Old 11-21-2018 | 10:57 AM
my 28 has a 40 gallon ballast tank placed infront of the second bulkhead under the deck and filled from exhaust water. it’s night and day difference running with it filled in rough water. Settles down any flightiness when running at 75/80 in that kind of water.
mickeymcclgn is offline
Old 11-21-2018 | 11:47 AM
Thanks for that information Mickey I thought it would be somewhere around that amount , are you single or twin motor .
Old 11-21-2018 | 04:32 PM
Craney's Avatar
Do you have twins or is it a single? Also do you fill the 40 gallons?
Craney is offline
