Wiring neutral safety switch >
Old 11-18-2018 | 10:42 PM
Default Wiring neutral safety switch
I have trs drives, zero effort shifters. I also have kill switches.
Starting from scratch so advice needed and appreciated.
Do I do this?
Fuse panel->neutral safety->kill switch->starter ??
ttrm007 is offline
Old 11-19-2018 | 01:22 AM
No. Neutral safety switch goes in the wire from the key (yelo/red) that goes to the slave solenoid to crank the starter. Kill switch goes in the wire from the key (Purple) that goes to the ignition system.
KEY Yelo/Red Wire>>>>>>> Neutral Safety Switch>>>>>>Slave Solenoid
KEY Purple Wire>>>>>>>>Kill Switch>>>>>>>>>>Ignition system
If you have the MercTrans transmissions they have a Neutral Safety Switch mounted on the shift linkage on them factory. Don't know if yours are still there or wired in.....if you have those trannys.
picklenjim is offline
Old 11-19-2018 | 09:15 AM
Thanks Picklenjim! I do have Merctrans. I'm not sure if the neutral switches are still there but if not I assume I may be able to find them. Am I better off using these instead of the micro switches in the shifters? They might be easier to service if one goes bad as the ones in the shifters would require a lot of disassembly to service.
ttrm007 is offline
Old 11-19-2018 | 10:49 PM
Well if their still on the trannys I would check if their still wired in and see if they could possibly be used. If they don't work then I would just go with the ones on the shifters. I doubt you could ever find those switches new anywhere. I may have some used ones. Mercury stopped using these trannys in the early 80's.
Just a FYI...if your winterizing make sure you disconnect the 2... 3/8" hoses connected to the cooler in the trans on the starboard side. If you don't and it freezes it will split the cooler inside the trans.
Old 11-19-2018 | 11:49 PM
I have the wiring diagram to that neutral safety switch and the way it works is it disables the slave solenoid by disconnecting the ground to it. When you find the switch on the tranny shift linkage it should have 2 wires coming off it. One wire goes to ground. The other wire goes to the negative terminal on the slave solenoid.
Old 11-23-2018 | 02:44 PM
Great info! I need to make sure those switches are still there and operational. Thanks!
ttrm007 is offline
