Tool room springs and spring oilers update. >
Old 11-20-2018 | 05:28 PM
Thumbs up Tool room springs and spring oilers update.
New 2014
250hrs plus..
.632lift cam.(crane 651)
Springs only lost 15# of pressure..
Since most springs come 25# or more than rated on spec sheet these are still above the spring rate I need.
I`m reusing them, just saved me a bunch of money, head guy was surprised, he thought they`d be out the door for sure.
I give the tool room spring and spring oilers a big thumbs up. Keeping them cool seems to be the ticket ...
Now I can get a 15lbs turkey instead of the 12#er.
#winning!
ICDEDPPL is offline
Old 11-20-2018 | 06:19 PM
all our race motors had spring oilers. at 7800 rpm I am sure that helped keep them alive. back in the day everyone ran restrictors to limit the upper end oil with solids. I never thought that was a good idea with the abuse the valve train goes thru. I always felt that if the oil going to the top end was starving the bottom end then you needed a better oil system.
compedgemarine is offline
