AEM Display
Old 11-24-2018 | 11:16 AM
Default AEM Display
Anyone try using one of these yet? I am replacing my dash and gauges this winter thinking of using the AEM display and the 22 channel can sensor.
https://www.aemelectronics.com/CD-5-...-Dash-Displays
https://www.aemelectronics.com/produ...-sensor-module
cjo632racing is offline
Old 11-25-2018 | 09:49 AM
If I was redoing a dash , thats the route I`d go.
Like it a lot .
ICDEDPPL is offline
Old 11-25-2018 | 04:55 PM
b
Being old and challenged, WTF is a 22 channel can sensor? And as a multi Fountain owner how does it make your boat perform better?
I ask only because the engines are currently out of the Biotch for a spiff up, and we have considered a little upgrade. Hence the question about the can sensor power adder.
RaggedEdge is offline
Old 11-25-2018 | 05:54 PM
Rookie's Avatar
Originally Posted by RaggedEdge
b
The 22 channel can sensor module is to turn the signals from your analog gauge senders to digital signals so the digital display can use it correctly and display accordingly when you don't have EFI. Wire oil psi, Oil temp, water temp, EGT, AFR, knock... to it and then it converts the signals and sends them to the digital dash. (quick version)
Rookie is offline
Old 11-25-2018 | 06:27 PM
BUP
CAN for most marine OEMs started in 2001 for MPI engines.
The AEM unit is also for EFI / MPI and carb engines.
The most common user and seller for AEM products by far on the marine side is Boostpower aka Alexi S. I would buy from him and that would get you all the know how needed for questions and installs. I am sure it would be really hard buying online to get tech help after fact. Just saying.
BUP is offline
Old 11-26-2018 | 06:16 AM
I’ve looked at those and thought about redoing my dash with one. For a new build, I wouldn’t even bother with analog gauges, I’d use these. If you’re upgrading your dash anyway, I’d say go for it!
ToMorrow44 is offline
Old 11-27-2018 | 12:47 AM
I'm running the AEM CD-7 dash with logger and vehicle dynamics module in my boat. Also running the AEM Infinity ECM's. Alexi at Boostpower built my engines and is providing everything. He actually worked with AEM on the R&D of their marine products.
AEM makes an adapter that will allow you to plug in one of their ECM's in directly to a MEFI wiring harness. Makes upgrading to a modern engine management system a snap.
NN32 is offline
Old 11-27-2018 | 09:11 AM
Sounds like a winner. I let everyone know how it works out.
Old 02-12-2019 | 11:07 PM
Default Twins?
Can a CD7 display twins? Because they’re popular in cars, I’ve only seen displays with data from 1 engine. Can it suppprt twins? Any pix of the display w/ twins?
242LS is offline
Old 02-13-2019 | 05:24 AM
I do not believe so. In my opinion the display would be a bit small for twins. I went with 2 CD5 displays.
